UV Not displaying in the uv editor
jchen210149
Message 1 of 9
jchen210149
When I click a object in the scene ,cant see  uv in the uv editor
but when create new object, it can see
tried change Maya/2018/pref to prefold.  did not work
please help  !
Replies (8)
Message 2 of 9
damaggio
Have you updated Maya?
Message 3 of 9
jchen210149
I am using Maya 2018 , but it works normal in other scene
Message 4 of 9
damaggio
Understood but maya has updates...1 ,2  just wanna make sure u are up to date.
The last time people had this issue the solution was to lower the texture resoultion for the viewport.
I dont see any problems here, is that only happening with that billboard plack? try exporting and importing again. just that piece....is this file .mb?
Message 5 of 9
jchen210149
its happening on all objects
I tried lower viewport resolution to 1024 but same
export / import didnt work
file is .ma
I'll try update maya
thanks for helping
by the way I was thinking maybe I should download 2019 instead of 2020 ,because  there usually will be some bugs in the new released version ?
Message 6 of 9
jchen210149
I put this script in mel   ogs -reset
its works ,but error happened again later a while
it works if I do it again but dont last long
find it here
https://polycount.com/discussion/197146/vanishing-uvs-in-maya-2018-uv-editor
so its my gpu ram cause this?
Message 7 of 9
damaggio
Yes, what's the rush, use 2019 for a while until they release the first 2020 update.
I don't know what else to suggest you for your glitch, im sorry, maybe someone else might chime in.
Message 8 of 9
Thank you for helping
Message 9 of 9
jchen210149
