We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Snap Movement for Pivot?
artur4EZV2
artur4EZV2
Is it possible to turn on SNap Movement/Rotate/Scale for pivot transformation as well?
Artur
brentmc
The pivot manip doesn't snap  when snapping is enabled in the tool settings but will respond to the snapping hotkeys - X/C/V/J
For example, hold down the X key and drag the center (or an axis) of the pivot manip to snap to the grid values/increments.
Similarly, holding down J and dragging the pivot orientation handle will snap to angle increments.
Brent McPherson
Principle Engineer
artur4EZV2
Thanks for elaborated reply!
Pity. No secrets for me here then.
If pivot transformation just react to the same snap option it would be just fine.
