smooth mesh preview to polygons cant undo
2200887
Observer Observer
2200887
Observer
Observer
the smooth mesh preview to polygons i cannot undo it as it is to many polygons and i do not know how to undo it ?
stephenkmann
preview is just a preview. there is nothing to undo.
1 for no smooth
2 for cage and smooth
3 for smooth
select the geo and press 1
hth
-=s
Observer
Observer
when i press one nothing happens it stays the same?
damaggio
That means that the mesh was permanently smoothed prior Mesh>Smooth and the history was deleted.
Open an earlier version of the scene before the smooth was applied.
Also make sure you understand how SubD workflow works.
stephenkmann
damaggio is correct. if you smoothed it with a polySmooth operation, and then deleted the history, then it's not smoothMeshPreview, but you smoothed the geo.
you can also try using
mesh --> unsmooth to get back the orig, if you did indeed smooth it. and you don't have a previously saved file with it un-smoothed
hth
-=s
