set normal angle
set normal angle
Message 1 of 8
set normal angle
where did 'set normal angle' go in 2017 update 3?
I can clearly see it in 2016 under the mesh display menu
Replies (7)
Message 2 of 8
brentmc
It was renamed to "Soften/Harden Edges" to better reflect its functionality.
The old name was misleading as it was not setting a user normal but rather hardening edges based on the angle between faces.
Brent
Brent McPherson
Principle Engineer
Message 3 of 8
thanks,
wasn't even able to google a solution for that one
Message 4 of 8
mspeer
Hi!
Please mark every answer that solves your problem as solution, so others interested in this thread will get a better overview.
Message 5 of 8
contact
Is there a way to set a keyboard shortcut for this action.
I was using it a lot before, and now I need to open the menu always 😞
Message 6 of 8
mspeer
Hi!
Yes.
Use the MEL command (check in Script Editor)
Message 7 of 8
contact
Hotkey would be perfect...
But I can't find the command...
Message 8 of 8
mspeer
Hi!
You need to create it manual ("Runtime Command Editor").
