Rebuild surface problem
mcw0
Advisor Advisor
Message 1 of 1
mcw0
I create 3 nurbsCircles and position and shape them.
Another view from perspective
I now loft 2 sets of 2 curves starting from the left most curve to create a 2 1-span nurbsSurfaces.
Now I do an attachSurface with the blend option.  Once blended, I turn on "Blend knot insertion" and set the parameter value at 0.25.
Now I want more spans going around the surface.  So I use rebuildSurface for only the U direction.   And I set the spans to 18.  The bottom surface is the result.  Not what I want.  Notice how the surface has changed in the V direction as well.  The middle surface is the original.  And the top surface is what I want.  Notice how the V direction hasn't changed.  But I had to do this manually by first rebuilding my loft curves to 18 spans.  And then repeating the loft operations and then the attachSurface operation.
Why can't Maya respect the U only direction for the rebuild surface function?  This happens in the V as well.  Basically, rebuildSurface is not doing the right job.  This is a bug but the Bug Report site is not displaying correctly so can't report this.
Replies (0)
