Problem with edge-loop tool
Hello everyone,
I have a tiny problem with the edge-loop tool.
I have a cube with one side open. Now if I use the edge-loop tool, all of a sudden the affected faces have black stripes on their surface which move when I move the camera.
What are those stripes and how can I remove them?
The only time I see that is when there are overlapping polygons, like when you do an extrude and don't move anything. Try grabbing two vertices and moving them around, it might uncover the polys to delete. And then you can just snap the virtices back into place.
An alternative would be to make a cube, place the edge loops, then open up a side.
