problem in line alignment using the vertexes
Message 1 of 16
i am trying to create a Chevrolet Camaro ZL1 in Maya using the blueprint... i am getting a problem to align the vertex lines according to the blueprint... the problem is according to the blueprint suppose when i move a vertex down in front view it goes down a little more in side view and again when i try to make it right in side view it gous up in front view...i hope you understand my problem...i need help about that please help me how to fix that problem...
Thank You
Replies (15)
Message 2 of 16
Enter reply text
Message 3 of 16
_sebastian_f
sounds like your images are not aligned well.
Message 4 of 16
So what should i do ?¿...can u tell me ur facebook name and profile picture...so that we could solve the problem by the help of pictures...?¿ Please help me i am stuck at this from last 2 months...
Message 5 of 16
And by d way thankx for replying Sir...
Message 6 of 16
_sebastian_f
facebook? no i´m not there! you have to post images here.
what you should do (if not already done) is taking a 2d app and check if the bluprints match at all. i found that it´s not always the case with blueprints downloaded from the www. if they match your problem is the scale or positioning of the imageplanes in maya. work on that.
Message 7 of 16
Ok...sir can u tell me from where i can post images...?¿...nd i also had another problm...the problem is i am getting some problem in my laptop so i will format it...but can i keep the Maya install file backup in another drive...or i have to download it again...i have downloaded Student version Maya 2017 for 3 years...or can i use my same email id to download it again...
Message 8 of 16
I mean what to do after i format my laptop...from where i can get Maya again...is it by downloading it with same id...or using another id...or keep the install files as backup from c drive...?¿
Message 9 of 16
Ny1 dere to help me please...
Message 10 of 16
_sebastian_f
late but:
no just copying the files forth and back usually does not work on windows.
format your laptop and re-install/download with your current id should work.
Message 11 of 16
Ok...thnk u sir...bt about my problem what should i do...i mean about images aligning in maya...i mean about the problem i asked u about in the topic...?¿
Message 12 of 16
U said a 2D app will help me...what kind of app actually...
Message 13 of 16
mujuningaiza
Adobe photoshop, GIMP, Krita etc those are image editing apps which will solve blueprints aligment
Message 14 of 16
Ok thank u a lot...Sir...
Message 15 of 16
But how this helps to make the alignment of the pictures right...nd Sir could u help me out about my problem as written in the topic...? ¿ please Sir...
Message 16 of 16
Is there a way through i can post images here to show what the problem is...?¿
