Announcements
Entire Object Moving When In A Component Mode
Maya was working fine and then all of the sudden the entire object would start moving when I would attempt to move an edge or a vert. Soft select is not on, if I press "b" then hold it down, brush does not even come up. Restarted Maya and tried again in a brand new scene and still not working. When I create a new object, say a cube, I also cannot alter the subdivisions. It is completely empty under Shapes - pCubeShape1.
_sebastian_f
still sounds like soft selection with a big radius. depending on your object size the radius indicator maybe doesn´t show up until you lower the radius a lot. have you tried just hitting the B key to disable soft selection? if it´s not soft selection open and check your tool settings and reset them.
It didnt turn out to be a soft select brush size error. Best solution I found was to save my custom shelf then delete the Prefs folder completely and restart Maya with a fresh start 🙂
