Please I need help!
Please I need help!
Please I need help!
I am facing with the following problem (the attached file) I highlighted the problem with red. Thank you for your help!
Moustakalis
I think your vertex manipulations messed with faces resulting some face overlapping IF I got it right from screenshots. You should be able to fix it with certain vertex manipulations as well.
Another solution WHICH IS A REALLY BAD HABIT that you should not get used to is to go to sculptin options and use the relax tool.
Upload the .ma file to help me further in case the case was not the above.
Thank you for your help I will try it!
saihtam
I'm pretty sure this is due to your camera settings. I'd play with the near clip plane of the camera. See my GIF.
03c035dd5007e944670def0696b79a6e
EDIT: You might have to click on the image for the GIF to play.
- Mathias
Wow! Thank YOU very much! I could solve the problem! Thanks again! 🙂
