Announcements
Maya 2016 selection in Maya 2017 ?
XtaaZ
XtaaZ
Hi there !
I've tried Maya 2017 for 2 months now, and I still got a lot of issues.
One of the most disturbing issue (and this is mostly the reason I'm still on 2016) is this (better in images, 2016 is first, 2017 is second) :
As you can see, for the exact same parameters, Maya 2017 doesn't want to properly select the face I'm pointing on (on both images, the cursor is on the top right corner of the facing face -the third one from the right).
Any idea why this is that way ? This is so annoying because it slows me down a looooot when I try to model something. I can't figure out why Autodesk changed this...
Another issue (but less disturbing), still for selection : when using the Tab Key (to "drag" the selection on several components), it also selects the components I can't see. It selects all components (vertices for example if in vertices mode) that are behind other components, which I don't want. To be clear, the "camera based" option doesn't work properly.
Any help would be appreciated, thanks a lot 🙂
mspeer
Hi!
I can't reproduce anything you described in your post.
Please try a reset of your preferences.
Rename the folder prefs in folder 2017 to something like prefs_backup, or to reset everything, the folder 2017 to 2017_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
XtaaZ
Hi, thanks for you answer.
This is the very first thing I tried to do, but it doesn't work...
mspeer
Hi!
Apart from a reset of the preferences i can only suggest updating the graphic card driver.
Please post your system specs (Graphic Card and OS).
Edit:
What happens if you change Viewport from Viewport 2.0 to a legacy one?
