Option window does not appear.
Message 1 of 24
Hello i am new to Maya and i am serious about learning this. I am just getting started with the tutorial in the Maya's official page. I am having problem following the instructions properly. There suppose to be a an options that should appear when i want to create something. For example: If i want to create a polygonal primitives cylinder, according to the tutorial an option window should appear where i can change the attributes, but it does not appear for me. I have to change the attributes from the channel box. I have already unchecked the Interactive Creation option as it says. I tried resetting MAYA, but no luck. Any idea?
Replies (23)
Message 21 of 24
wadoman1
None of the solutions here worked for me. Switching to a different or default workspace solved it for me.
Message 22 of 24
andrey_zhukov
Thank you! That helped 🙂 Last time I also spent a lot of time figuring this out 😕
Message 23 of 24
Chanelle.Keoghan
Observer
Observer
If you are working via parsec and you have virtual monitors, go to your computer Display Settings and switch the monitors around to find what screen it is appearing on - move it to where you can grab it and set monitors arrangement back.
For me I could not grab it via Shift + Right Click over windows taskbar and arrow keys to move it, or cascading
Message 24 of 24
ccorrealowrance
Community Visitor
Community Visitor
Thank you! 11 years later and this is still happening, I guess.
