No Edge loop on wedged faces
ch.niebel
ch.niebel
new to Maya. I modelled sth testing the wedge tool. Afterwards I want to insert edge loops along the side of the mesh using the Multi cut tool but it cannot identify the mesh flow along the wedged polys. Is there a way to insert a complete loop like in the second image?
mspeer
Hi!
Try Bevel.
damaggio
you can also extrude the entire area and use offset but edge loops only work on quads.
ch.niebel
Thx. I am suprised how poor the edge loop insert algos are in comparison to other apps.
mspeer
Hi!
You can't have a "loop" on a triangle as you have no clear opposite edge, in contrast to a quad face.
Please mark every answer that solves your problem (or gives the correct answer) as solution, so others interested in this thread will get a better overview.
damaggio
That could be true that other apps might have a superior tool,however Maya is still the best choice overall, that's why you are learning it.
Have fun.
hamsterHamster
Basically, you can use OffsetEdgeLoop tool instead, then double-click+del unnecessary edge. And, to avoid triangles, you can do Wedge with some small inner radius.. the result will be all quads, which means you can use InsertEdgeLoop tool.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
