Need help with moving vertices Maya 2016
I have to move these points along the surface. I used Move tool in normal mode but wasnt successful. Can anyone please help me out?
damaggio
to move along the surface use the modeling toolkit under "transform constraint" there's 2 options Edge slide and Surface slide...see if that helps.
Ha.... You are a lifesaver.....
I was stuck at this part for a day. Oh god, thanks to this forum that I found a solution.
