- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to simply use the Grab brush with the live object turned ON, and at least in Maya 2024 and Maya 2025 seems to be broken. I've used this before when this feature was released several years ago and it worked great. I don't want to use the live object with quad draw, just to be clear.
Can someone test this and let me know if it works on your end?
Steps:
- Create a torus, subdivide the torus, and do some soft vertex move to deform the geo a bit.
- Create a second torus.
- Delete history on both geo
- grab the first torus and set as a live object
- now select the second torus and then press move brush sculpting tool
- Try to move the vertices with the brush
Expected Result:
- Seeing the vertices slide across the surface of the live object
Bug:
- Crackling vertices flying over to the center of the grid randomly
