Modeling with another object ?
Hi everyone, there is something I think about modeling.
Sometimes it 's hard to extrude in some parts. It is simpler to model a cylinder and put it on the roof while it takes a minute to extrude one cylinder from the face. If the final image in the model gives the desired result, does modeling cause a problem in this way? (Outside Smooth)
sean.heasley
Hi @Anonymous
Nope! This doesn't cause any problems and is often times the preferred way to model especially when working on buildings like these.
You may just need to watch out for faces that are inside the other objects and delete them accordingly so they aren't taking up UV space and/or clashing with other faces.
A friend of mine at Eidos has a simple breakdown showing how modular modeling like this is done you can find here!
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
