Modeling: Why are some polygon objects dark?
Message 1 of 11
I'm modeling a cartoon man. I've started working on the shoes but the shoes look dark. Darker than any other body part. Why is that? At first I thought it was the normals but i flipped that, it didn't help.
I'm also modeling the teeth. I have the same problem there. I don't know why but they're looking pretty dark. What should I do? I'm using maya 2015.Screenshot (20).png
Replies (10)
Message 2 of 11
pshwayka
Have you assigned any materials to the model, or are you just using the default Lambert?
Message 3 of 11
Nope, I haven't assigned any materials.
Message 4 of 11
damaggio
Are your Normals facing out?
Message 5 of 11
pshwayka
In her first message, she said she had checked that, but they really do look reversed, don't they?
Message 6 of 11
pshwayka
What happens if you switch viewport renderers? Right above the viewport, click on Renderer and try one of the Legacy options and see if that makes a difference.
Message 7 of 11
Thanks, it doesn't happen when I switch to legacy high quality viewport. what does that mean?
Message 8 of 11
pshwayka
Might have something to do with your graphics card.  It seems like different cards perform differently using Viewport 2.0.
Message 9 of 11
Thanks! Mystery solved 🙂
it never happened with maya 2014 😮
Message 10 of 11
pshwayka
That may be because 2014 didn't default to Viewport 2.0 so you probably never noticed...
Message 11 of 11
I don't think that will affect the mesh when I start texturing
