model is selecting random vertexs
i managed to rig my model and all. i started using the shape editor to make her facial expression. everything was COMPLETELY fine, until today, where when i select vertices, it moves a completely random vertex!
note that soft selection ISN'T on. When i use soft selection, it does the same thing, it selects other vertices making spikey detailsnote that soft selection ISN'T on. When i use soft selection, it does the same thing, it selects other vertices making spikey detailsin one save, the vertices WERE acting normal by deleting the shape editorin one save, the vertices WERE acting normal by deleting the shape editorbut now when i reload it. it goes back to selecting unintended verticesbut now when i reload it. it goes back to selecting unintended verticesmore problems 4.pngI'm going to attach the maya file this time, and HOPEFULLY, there will be a solution to this problem.
reminder: soft selection ISN'T ON
mspeer
Hi!
The problem is the polyMergeVert1 node.
Don't change your mesh/topology after binding the skin.
Simply use
Edit -> Delete by Type -> Non-Deformer History
it worked!
thank you so much...
