Model crushes mesh when pressing 3 to smooth
Hello, beginner to Maya here. I am following a Udemy tutorial to make a K-bar knife and am constantly running into an issue where when I press the 3 key to smooth the model it either crushes into a spiky mess, vanishes or flies off the window. I have no idea what causes it or how to fix it other than constantly having to press the 3 key to see if any edits to vertexes/edges/faces trigger it. Please help, I'm at my wits' end. I've attached screenshots of what it looks like before and after I press the 3 key.
mspeer
Hi!
This could be a problem of your object or the GPU / driver.
Without a scene-file i can't say which of these 2 is responsible.
Lindsey_Robbins
You have a lot of faces converging at that one point in the center. Anything more than 5 points into once spot can cause weirdness. Not sure if that has anything at all to do with your smoothing problem, but in general, that's a thing to be avoided.
Here's the files!
I think it is better if you show the mesh. Anyway, even with something crazy shouldn't be crashing. Somebody said that more than 5 edges vertex causes weirdness, that is not true.
You can always apply a "smooth" on the mesh and see how it behaves.
mspeer
Hi!
That's an image and not a Maya scene-file.
Please upload the Maya scene-file (".ma" or ".mb", maybe ZIP it first).
If you don't want to make the scene public, you can also send me a link in a Private Message.
