Maya 2019 Mirror Bug!
got some weird issues with the mirrortools on 2019. Cut Geometry doesnt work on value "0"
mspeer
Hi!
Cut Geometry does only work as long as if there is an intersection.
https://forums.autodesk.com/t5/maya-modeling/mirror-tool-direction-does-not-seem-to-be-working-in-ma...
Please report this problem (bug?) to Autodesk.
In Maya main menu:
Help -> Speak Back -> Report a Problem
It's definitely broken in maya 2019. I used the mirror function over 1000 Times in 2018 and its work as intended. Not yet anymore.
  • Bugged with the "0" value like in the Video below (worked fine in 2018)
  • Direction did't work in "Cut Geometry" mode
  • Mirror Operator applied double in like 1/10 cases (its quite random) and often destroys the mesh (even on delted history)
GUYS CMN - Double Mirror Node is still in there. Is this really that hard to fix....
