invisible objet
invisible objet
carlasampaio1234
invisible objet
carlasampaio1234
Community Visitor
Community Visitor
I can t see a modelization that I did recently ( yesterday). I can see the arrows to move my modelization but I can see the object. It s not a problem with the H.
excusez moi, mon objet maya n 'est plus visible je sais pas comment faire. je peux le deplacer car je vois les fleche mais je ne le vois pas
et c'est pas H le soucis
qlq sait?
hamsterHamster
What do you mean by that? A hotkey H? It toggles the Visibility channel ON/OFF.
So, make sure you have the Visibility ON, like this:
If there still is no visible object, then click DownArrow (this selects the Shape node), and click the H hotkey again.
If still no success, post the scene itself.
Honestly speaking, I would redefine that command to the Ctrl+H hotkey, as the single button hotkeys are too easy to click accidentally.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
jakefellman
If toggling visibility with hotkey "h" does not solve your problem, there is a chance that your pivot point is out of place, and your actual mesh is far away / outside of the pivot. Select the object in the outliner, and go to the "modify" dropdown menu. Select "center pivot" and then press F on your keyboard to focus the camera onto the mesh.
