Impossible to Quadrangulate
Hey, I dont know what I should write here.
I've a problem with a mode. All faces are triangles, and i can use the "Quadrangulate faces".. Its just doesn't work with THIS EXACTLY model.
I tried:
Open .obj in Maya 16 and 17.
Use "Quadrangulate faces" in separated faces, not all the object.
Search in Autodesk's Help Center.
Search on Google.
Search on YouTube.
Ask my classmates (not the best option, it was 1:00 AM, so they're sleeping).
Ask God ''Why?''.
Reinstall Maya 16.
Ask AutodeskHelp in twitter (they told me to ask here)
tony.su
Autodesk Support
Autodesk Support
Could you zip and upload your scene file? I will test it.
Tony Su
Product Support
damaggio
Most of the time Maya quadrangulate does not work, but the Facer script works 100% all the time....go get it.
Please, use it only to see the bug.
http://www.mediafire.com/file/t7za9a44eiilg6o/BastionNew.zip
I dont know how to use it, where can I download it?
mspeer
Hi!
Open the Option box of Mesh -> Quadrangulate and uncheck "Keep Hard Edges" and "Keep Texture Borders".
You can also do this later in Attribute Editor if history is enabled.
This action may result in some unwanted effects on some parts of the mesh, but this related to the (low) quality of the model.
(You can select only the faces you want to be effected by Quadrangulate)
Oh, that easy ;-;
THANKS!
