How to trim a bunch of curves...
V4nDl0
V4nDl0
Is there any way in Maya to trim a lot curves at once? Like a boolean operation, or a cut tool that will make a slice through multiple curves? At the moment, I'm deleting CVs to manually chop off each curve near to where I want them to finish and then moving the CVs one by one to align precisely. Is there a quicker way I could try?
_sebastian_f
sure:
create another curve where you want the cut to happen.
select curves to be cut followed by the the cutting curve and open curves > cut (option box). adjust the settings to do what you need and hit cut.
V4nDl0
Great! thank you so much.
