how to Create polygon Cube in 1 Click ?
man.in.kuwait
man.in.kuwait
how to Create polygon Cube in 1 Click in Maya?
I don't want to drag the base of the grid and pull up for hight ?
select the poly cube tool.
hold "ctrl" and click the mouse.
this will work for all the poly/nurb tools that require this.
Hope this Helps
You can also disable Interactive Creation (or something similar to that, I don't recall) in the Create menu.
man.in.kuwait
thanks alot!
it works 🙂
i disable the Interactive Creation.
This was very helpful to me as well! Thank you truly...
:0 )
Untitled.pngDisable this!
did you disable the Interactive Creation?
now
Deselect all
Shift+ Right click  > Cube Smiley Indifferent
don't follow Create > Polygon > Cube  or  Shelf Tabs > Cube Smiley Indifferent
your little Finger is Always on Shift . isn't it ?
