Announcements
How to create edge beetween two vertices
Silverland
Message 1 of 9
Silverland
Here on the simple exampe i am showing you the problem. How do i connect beetween two vertices so that it will create edge there only
Replies (8)
Message 2 of 9
mspeer
Hi!
You can't.
An Edge needs an adjacent face.
Message 3 of 9
Silverland
Its very sad because it could be very handy in some modelling cases. In Blender you can do that.
Message 4 of 9
huh interesting. i am used to maya. when would that help?
Message 5 of 9
timdan
I'm curious why you'd need an edge without a face? You can use the bridge tool in your example to close in that whole if that's what you're after.
+ timdan
http://www.timdan.com
Message 6 of 9
Silverland
Here is the answer guys on your questions why i need to do that. Watch this Blender tutorial and you will understand why extruding single vertices can be useful. https://www.youtube.com/watch?v=MdAR-O_DwSs
You  can make a whole model by only extruding the vertices,connecting them and then fill them with faces in one click like he does it at 6.52 on tutorial. And this is just one example but i remeber when i was modelling this car in Blender -https://www.youtube.com/watch?v=dhESzRJgv0Y i was using it a lot in different places of the mesh
So basically extruding single vertices can be very useful for tracing the object. For example when you use blueprints you trace blueprint all the way around and once you happy you just fill the holes with faces
But it seems like Maya allows extruding vertices but its completely useless because you cannot  fill them with faces or even connect two vertices together
Message 7 of 9
timdan
Oh, I see. That's what the curve tool is for in Maya.
+ timdan
Message 8 of 9
Silverland
Thanks i need to learn more about Maya curves, hopefully its reliable replacement for this Blender feature of extruding vertices. In Blender you can do this with the curves as well but i hoped i could do this with vertex in Maya
Message 9 of 9
mspeer
Hi!
You may also have a look at:
Mesh Tools -> Create Polygon and
Modeling Toolkit
"So basically extruding single vertices can be very useful for tracing the object"
There are multiple other ways to do this in Maya and other 3D applications.
