How to create dashed line?
Message 1 of 26
Hi, can anybody show me how to create a dashed line in video?
Replies (25)
Message 2 of 26
mspeer
Hi!
Paint it on a image/texture and use this image/texture in your software.
Message 3 of 26
Hi mspeer, how to edit the line in this project file? see attachments.
Message 4 of 26
mspeer
Hi!
You can use any Deformer to deform objects in Maya (even a curve).
Not sure what you want to do, but maybe it's easier to start with curves and then from there create the pattern.
Message 5 of 26
Do you mind if you can show me in video tutorial? I want it same like in this project file. See attachment. (Lines.mb)
Message 6 of 26
I have tried to create a beizer curve in this project file, but it doesn't appear. Do you know why?
Message 7 of 26
mspeer
Hi!
This scene makes use of Legacy Render Layer.
Either switch your Maya to  "new" Render Setup (in preferences), or
use import instead of open scene.
Message 8 of 26
Ok, thank you. So, the red dashed lines can be edited? For example make it shorter or longer or curves?
Message 9 of 26
mspeer
Hi!
Yes.
Message 10 of 26
Oh ok. How to edit these red dashed lines?
Message 11 of 26
mspeer
Hi!
OK, back to my first answer:
Message 12 of 26
Hi, I  have tried that but it didn't work. Can you show me how, please? Thanks.
Message 13 of 26
mspeer
Hi!
Please describe step by step what you tried.
Message 14 of 26
I'm using Maya 2018.
1. Import file
2. Select one of the dashed line
3. Select Deform > Nonlinear > Bend
Message 15 of 26
mspeer
Hi!
You need to rotate the deformer.
Message 16 of 26
I did but didnt work. Something wrong with the software?Screen Shot 2018-06-19 at 4.33.29 PM.pngScreen Shot 2018-06-19 at 4.33.29 PM.png
Message 17 of 26
mspeer
Hi!
Choose other axis, look at my screenshot.
There is nothing in up-axis at your object which can be deformed.
Message 18 of 26
I have tried hundred times.. there is no axis on the object for Deform.
Message 19 of 26
mspeer
Hi!
1. Rotate along object (see red line)
2. Adjust the value for curvature in your deformer.
I recommend to try and learn how to use a deformer with any other 3-dimensional object first.
Please read the Maya Online Help / Documentation for more details.
Message 20 of 26
I think its hard to edit it. Do you know how to make new dashed lines?
