How to Bevel Multiple stacked edges?
Is there a way to bevel all the selected edges uniformly together?
hamsterHamster
To manipulate Fraction for all the objects simultaneously, you'll need to select all the newly created Bevel nodes. This can be done by exposing construction graphs of the objects e.g. in NodeEditor. After applying bevel you just click InputAndOutputConnections button and select all the Bevels, then in channelEditor/pop-up-attributes you can enter the values that will affect all edges equally.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
