How do I delete a cube?
I placed a cube, then selected it, then pressed delete, but it is still there.
How do I properly delete it? I can do CTRL+Z to undo the creation, but I'd like to learn how to delete it without having to undo all my prior work.
Thanks in advance!
_sebastian_f
should work like this. make sure you are in object and not in component mode.
mspeer
Hi!
There is a bug in Maya 2017 (and udpate1) that sometimes prevents from deleting with the delete-key in Viewport and Outliner.
Workarounds:
A) Windows -> Workspaces -> Reset ... to Factory Default (This works for most Workspaces, but not all)
B) Change the Workspace
C) Save Scene, Exit Maya, Re-Start Maya and Open Scene
temporary solutions (do no not reset the delete-key behavior):
D) In Main Menu: Edit -> Delete
E) Middle-Mouse-Click in the Viewport before hitting the delete-key
