FBX import not overwriting
MayaNZ01
MayaNZ01
Hi there
I am wondering why when I import an fbx which I have modified the UV's in an external software will not replace the current object when importing. I have to rename or delete the object if I want the new one with updated UV's
damaggio
MayaNZ01
Thanks for outlining that, I guess add is better than not importing but it just means renaming everything. So there is no way to overwrite? I have seen people ask why is it overwriting on fbx import
damaggio
Ah , I see what you mean, how about the default import settings, it doesn't overwrite the existing mesh?
MayaNZ01
Unfortunately not, it just doesn't import if there is a name clash
damaggio
Yes ,you will need to rename the object in the scene or deleted it before importing the new one.
