Extracting Faces from a mesh causes new mesh to have unconnected vertices
asalastrying
asalastrying
so i have a body mesh i want to extract the face as a separate mesh, i go through this process:
1. select the faces of the mesh i want to separate
2. click Extract with keep separate extracted faces option checked with offset of 0
3. i check Keep Faces Together on, with the rest set to 0.
after that i get two meshes like i wanted the body and the face, but the face mesh has some random vertices that are unconnected now.
am i missing something in the process? if not how can i fix it? merging the unconnected vertices works but there are so many its not possible to go through them all to check
damaggio
Just select them all and use the merge vertices tool on the face.
asalastrying
it doesnt really work, have to select the two unconnected vertices and merge them, which is fine but the problem is that i cant see which vertices arent connected till i check manually.
artfully3d
Vertex mode, on the piece that has disconnected vertices.
And as @damaggio said, just select literally all of them --> Drag select over the entire piece
Then do a merge operation, if you set your merge value small enough, this will catch any overlapping vertices and reconnect them.
asalastrying
yes thank you both for the help!
the problem i was having is double vertices and i was setting the threshold for merging too large or too small.
