Errors with Mesh and UVs
castanedakevin1424
castanedakevin1424
I finished a model in Maya (2024) I was working on and thought the UV's were fine. I then tried importing my mesh into Substance Painter to texture but then it wouldn't load the scene. I then went back into MAYA and then redid my UV maps and it still wouldn't load into substance painter. There was no issue with substance painter as I went and textured something else and it'd load so I figure the only issue is with the mesh/UV.  I was hoping someone could point me in the right direction with this and much appreciated! I've attached a file of the model I was working on and a screenshot.
Just FYI, its two objects in the scene I UV mapped both.
damaggio
Did you recover your timeline?
castanedakevin1424
Yes
damaggio
You left that post open without a solution , you need to reply so you can help the community resolve  similar issues.
damaggio
You have 2 UV sets on that mesh.
castanedakevin1424
So do I export the two meshes separately?
