Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
// Error: Unfold3D process error. with Ryzen CPU
Message 1 of 12
Hi, I have troubles with unfold3D plugin in Maya 2020!
When I try to unfold UV with Unfold3D I have this error:  // Error: Unfold3D process error.
I have an AMD Ryzen 7300X processor and after some online research I found out that Unfold3D has issues with AMD Ryzen CPU.
With Maya 2019 I had the same error.
I tried to disable the SMT in the BIOS as suggested on the bug page but it didn't work for me!
I tried also to check the plugin in the plugin manager menu but the issue is still there.
Does Anybody know if there is a way to fix it?
Thank you very much!
Replies (11)
Message 2 of 12
mspeer
Message 3 of 12
Thank you for your reply,
yes, I have already found out this post, but there are no solutions in there.
Or maybe the answer is simply that there are no solutions.
Is there no hope to see this issue fixed in a future release?
In that case it would be really annoying... for me now it is not possibile to change my PC, so I have to switch to another software!
Message 4 of 12
mspeer
Hi!
"Is there no hope to see this issue fixed in a future release?"
- As it can be reproduced now, there will be very likely a solution for this in future.
Message 5 of 12
goran.milovanovicLVTYC
"As it can be reproduced now, there will be very likely a solution for this in future."
In this lifetime?
I wonder if anyone has a need to use this feature of maya or is it just handfull of people like me that find this bug very important?
Message 6 of 12
Message 7 of 12
Funny fackt. Unfodl3d stand alone works perfectyly so???
Message 8 of 12
Just posting because this is incredibly annoying
Message 9 of 12
Hi, I tried to solve the issue replacing two files as explaned by TOMOX in this other post:
https://forums.autodesk.com/t5/maya-forum/unfold3d-process-error/m-p/9430890#M80359
It worked for me!!!!
Message 10 of 12
How about Maya 2015?
Message 11 of 12
Why hasn't this issue been solved yet? Threadripper 2950, Maya 2022 and I can't use unfold on even mid poly meshes. Crashes maya almost all the time. WTF?
Message 12 of 12
The issue actually seems to be resolved for me in Maya 2022. Possible there
was some carry over from when i fixed it previously, but I don't think so
(Ryzen 3900x)
