AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Edge won't delete
Edge won't delete
Edge won't delete
Hello all,
I'm fairly new with Maya, and I've run into a problem with a lone edge that I can't delete - it seems to be made up of several short edges. It's also part of an extracted object in a different space. I have tried using the delete button, and edit mesh > delete edge/vertex with no luck. Anyone know what may have gone wrong and how I can fix it?
I believe I figured out the problem- although I don't quite understand how it happened. I was able to go through all the extra edges/vertex in this photo and delete them.
mspeer
Hi!
It's hard to tell from screenshots what's wring here.
For further help please upload a scene-file.
Please mark every answer that solves your problem as solution (also if it's you own message), so others interested in this thread will get a better overview.
I am uploading the scene file along with this post. I thought I figured it out but whatever I did seemed to cause a chain reaction and I have a lot of strange edges now. If you look at the scene file you'll notice a lot of stray edges in inside head and neck of the dog. Any help with this would be greatly appreciated!
mspeer
Hi!
You have multiple vertices/edges on top of each other which lead to faces with zero area.
Correct theses problems. Use Edit Mesh -> Merge (Vertices), that should remove most or all problems.
This worked! Thank you!
