04:42 AM
Here's my problem. When I try to dublicate special an object to make it an instance and reverse it by -1 on the x axis for some reason it turns black. What's happened is that the faces have turned inside out and when I try to remedy this by going to Modify - Freeze Transformations it unfortunately reverses the faces on the other half which isn't fixing the problem. I have attached some screenshots to better explain the problem.
Thanks in advance!
