Object turns black when scaled...
Message 1 of 11
Here's a problem I'm having that probably has quite an easy answer but I'm quite new to modelling so forgive me! When I scale two grouped objects by -1 on the x axis they turn black after trasnforming, how do I fix this? I have attached a screenshot to show you what I mean.
Replies (10)
Message 2 of 11
Anifex09
need to see a wireframe. do you have AO on in the viewport ?
Message 3 of 11
Here's the same screenshot with a wireframe, AO isn't on, I haven't messed around with any shaders or materials.
Message 4 of 11
Anifex09
you didn't attach an image. Did you use boolean to create the windows. Try setting your scale back to zero and delete the history (select the object - Edit pulldown - Delete by Type - History)
Message 5 of 11
Anifex09
I made a mistake set the scale to 1 then delete the history
Message 6 of 11
Oh sorry, here's the file, deleting the history didn't work! Thanks for your help by the way 🙂
Message 7 of 11
Steve_Curley
All files (except images) must be zipped (and only zip, not any alternative) or they will not attach. Please zip your file then try attaching it again.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 8 of 11
Oh sorry, I didn't realise, I also attached the .mb file if that helps!
Message 9 of 11
Anifex09
Just select your windows_side1 group - goto Modify - Freeze Transformations. Sometimes when we scale an object in your case the X axis with a negative value we can alter the interpolation of the normals in the viewport.
Message 10 of 11
Thank you so much! It worked 🙂
Message 11 of 11
Use "Mesh Display" -> "Reverse"
