Deformation of Mesh when Modeling
I am using maya 2018 and haven't used it since maya 2016. Not sure if this is some new setting I am unaware of of a bug but it seems whenever I try to manipulate faces/vertexes/edges, some very odd morphing happens. In the example, I moved the selected face outward on the x axis. Normally, it should keep its square shape but instead, makes some odd shapes. It is like the object cannot be manipulated beyond the size of the object. I have deleted history on the object but the problem persists.
sean.heasley
Hi @Anonymous and welcome to the community!
Does this happen every time you create a cube from scratch and try to move a face?
You can try opening the Move Tool settings and hit Reset Tool.
I'm almost positive I've seen this before but I'm drawing a blank trying to remember what causes it Smiley Frustrated
That said, resetting the move tool should solve this. As well please try creating another basic cube and then try to move the face.
Please let me know if anything changes!
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
