- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Why does my model look like this? Even when I apply a Ai Standard surface, the dark spots appear on the render view.
Have you tried to unlock and unitize the normals? Modelling> MeshDisplay>..
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
@hamsterHamster is on the right track. Change to vertex mode and select the offending vertices. Then, from the Modeling menu set, select Mesh Display>>Set to Face. This should fix your problem. Although, the vertex normals will not be averaged. If you want to average them after you have set them to faces, then select Mesh Display>>Average.
thank you, it worked!
im really new so im not really sure what those things mean but they fixed my model.
