Creating a 3D building but need help ASAP
Message 1 of 10
Hi I’m currently modelling a 3D building into a house but I don’t know how to cut out a windows or doors
on onto my project and texturing a it inside and out. Plus I need the lit the building as well
I’m a beginner person , if you would do a screen share my maya project and see if I would need more help on it or not
Replies (9)
Message 2 of 10
damaggio
First , post images of your progress so far.
Message 3 of 10
Its_jay
There is other programs out there for creating building
but if you wanna use maya for this part
with insert edge loop make your door and windows shapes
then delete what’s inside the shape > after that
(just one way)
Message 4 of 10
Plz send me a instructions step by step how to make windows, doors and a roof etc ASAP
Message 5 of 10
whisper1
There are lots of ways to do anything in maya.
Welcome to the headaches.
I prefer to make my box for the building/house/room/whatever, then create other boxes or cyls to use as cutters.
If you want to cut multiple holes at once, select all your cutters, then go to edit mesh/combine. Then take your new surface and edit/delete by type/history.
Now select your main object, select your cutter(s), and go to Mesh/Boolean/Difference. You will get some extra lines that you may not like that lead to corners that you have cut into the building. You will need at least one of these per surface.
delete by type history when you're done.
As for texturing and lighting, those are way bigger topics. There are entire boards dedicated to them. Finish building your structure, then get to them.
Hope that helped.
Message 6 of 10
You said something about selecting a cutters but I don’t know were it is in mays though?
Message 7 of 10
whisper1
a cutter is just a shape that you make: cube, cyl, whatever. You make it the size and shape you want, move it where you want the hole to be (roughly), and that's it.
Select the object you want cut, select the object you want to cut with, mesh/boolean/difference.
You may have some extra faces, but that's easy to take care of.
Alternatively, you can use the cut faces tool, cut some lines into the room you're building, select the door/window face you've just cut, delete it/them, and move the vertex points if needed.
Message 8 of 10
whisper1
Did that work? Still need help?
Message 9 of 10
Hi
Still need more help
Regards
Naveed Ashraf
Message 10 of 10
Yes still need more help though including a how to do a roof and lit the building
