- Mute
- Permalink
- Report
Okay, so I have recently started using Maya again after being gone for a week and never had this issue until today. I tried restarting Maya and creating a new file, but it won't go away so I believe I may have pressed something, but not sure what. Let's say I create a cube, well this cube will either begin with some form of rotation on all axis, or when I go to scale it or move it, it will gain some rotation on all axis. If I go to scale the edges so I can straighten things out they will expand rather than flatten out. Also if I go to the objects properties and add edges like to make a cube with say, 4 squares on it's different sides it will discombobulate the entire shape into some mongoloid monstrosity. Keep in mind I have not edited any of the object properties this is the first place I checked, and it happens on objects that are not in a group or a child object. I have also not moved a single vert so I'm just lost and confused. Some help would be most appreciated.
