AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Connect group of vertices
jefersonfagundes2006
Hello
I have a plane with 3 vertices at top and 3 vertices at bottom and I want to connect them and create a line between. There is any way to do this without having to select 2 vertices then apply Connect and so on…I mean, select the vertices in order that I want to them connect and then select some option to connect them in this order?
Thank you.
damaggio
Use the weld tool
Hi
Weld Tool will merge vertices, I want to create an adge (line) connecting the vertices in the order they were selected. I have a mesh with 100+ vertices, if I connect one by one it will take a long time to finish.
damaggio
Try to triangulate the mesh then quadrangulate. You can also try to delete all floating vertices and use the insert edge loop tool and add the desired subdvisions.
But most importantly is to learn to think ahead of the game so this does not happen.
Kahylan
Delete the polygon, select the edges on the top and the bottom and use the Edit Mesh -> Bridge Tool
