Change scale value without actually changing size
So I created box and changed the scale. I would like to keep those values even after modifying the object. So for instance when I do boolean operation the scale of box turns back to 1 at all dimensions. So is there a way how to change the value back to the original but without actually affecting the scale.
sean.heasley
Hi @Anonymous
If you go to Modify->Freeze Transformations that will keep your object at the scale its at but set all the values to one which should do what you're looking for.
Please let me know if this works or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
mspeer
Hi!
Using Boolean creates a complete new object based on 2 or more input objects, so there is nothing to keep.
You can only try to re-create those values.
