Can't move UV's in UV Texture Editor
Message 1 of 14
After making planar UV mapping and opening UV Texture Editor, when move UV with manipulator, UV not moving with it.
Windows 7
Asus P5Q, Quad core 2.6
ATI FirePro 5700
Maya 2010
Thank you for your help !
Replies (13)
Message 2 of 14
n8skow
When you try moving the UV, do you see the texture adjust in the Perspective View?
Possibly a display issue with the ATI card - they don't get along with Maya very well under Windows.
Message 3 of 14
Nothing move. but I've notice a warning message : Some item cannot be move in 3D view. I don't know if it's related. Also, some time, uv's move but did not follow manipulator. The UV's that I tried to move are way out of the manipulator focal circle.
Message 4 of 14
Wierd!
Make sure that the snap component isn't turned on e.g. 'snap to grid' or snap to point.
Then try right clicking in the Texture Editor and selecting UV in the marker menu. Try selecting and moving UV's this way.
... Or try selecting the vertices then converting the selection in the Texture Editor to UV's.
Can't think of anything else!
Message 5 of 14
n8skow
Make sure your selcting UV's, not vertex.
Message 6 of 14
Thanks to all but I find it, there is one setting to change in Windows menu !
Go to : Windows\Settings/Preferences\Performance Setting.
In Dependency Graph Evaluation, select "Drag" radio button, insthead of "Release" radio button.
That's all. Work like a charm now !
Message 7 of 14
This solved my issue:
UV Editor > Tools > Move UV Shell []  >  Transform Constraint: Off
Message 8 of 14
I followed all the solutions provided but i am still unable to move UVs in Texture Editor
Message 9 of 14
agnisen07
UVEditor > Polygon > Unpin All.
This should work. The Move UV Tool works but only for moving the shells, and doesn't address the actual issue which is your UV's must have been gotten pinned somehow.
Message 10 of 14
UV Editor —> Tools —> Move UV Shell [ ]
the Move UV Shell pops on the right part of your screen.
press W, so that the move tool is selected.
In the new options that have appeared under the Move Tool menu
set the Step Snap to Off.
Hope that helps.
Message 11 of 14
The same process can be followed for the Scale, Rotate Tools as well.
Message 12 of 14
uv editor - edit - unpin
Message 13 of 14
I know this post is 10 years old, but you deserve a big thank you!!!!! fixed my problem
Message 14 of 14
itaibachar2012
Thank you! from 2021...
