Ability to smooth a mesh in Maya using Hard edges to control the subdivision
Message 1 of 11
Does anyone know if its possible in Maya to smooth a mesh using Hard edges to control the subdivision (see attached 3DS Max image).
The only option I can find in Maya is to use the Maya Catmull-Clark option and use ‘Propogate Hard Edges’ and ‘Preserve Hard Edges’ but it doesn’t work the same way as 3DS Max does.
The only workaround I’ve been able to find in Maya is to extract the faces (keeping them part of the original mesh) and it then smooths both surfaces separately just like 3DS Max.
Replies (10)
Message 2 of 11
mspeer
Set Subdivision Method/Type to
- Maya Cutmall Clark, and check
- Preserve -> Hard Edges
Message 3 of 11
Thanks for your rely - see image below, this is the result I get when I use the 'Maya Catmull-Clark' smooth option and 'Preserve Hard Edges' option. (compare this to 3DS Max screenshot - very different result). I'm hoping there's something simple I'm missing here.
Message 4 of 11
mspeer
Hi!
No, you are not missing anything.
The only way to achieve something similar is by using Creases.
https://help.autodesk.com/view/MAYAUL/2018/ENU/?guid=GUID-DEB060F9-A4B1-4F73-8B4D-B18A13D0E54B
Your workaround with Extract is OK, but i would prefer Detach as it's faster and then of course use Merge later to combine the vertices again.
Message 5 of 11
malcolm_341
Adding to mspeer's suggestion, this is how you can get the exact sharp edges you want and not have to go through a lot of menus each time to make this a viable workflow. There are three scripts below with descriptions of what they do for each script.
//Set mesh options to receive creasing correctly
string $selection[] = `ls -sl -fl`;
//Get object name
toggleSelMode;
toggleSelMode;
selectMode -object;
string $objName[] = `ls -sl`;
//Get shape name
select ($objName[0] + ".f[0]");
string $getShapeName[] = `ls -o -sl`;
//Turn off Use Global OpenSubdiv
setAttr ($getShapeName[0] + ".useGlobalSmoothDrawType") 0;
//Turn on propogate edge hardness
setAttr ($getShapeName[0] + ".propagateEdgeHardness") 1;
//Turn on Maya Catmull-Clar
setAttr ($getShapeName[0] + ".smoothDrawType") 0;
select $objName;
//Turn on crease for selected edges and harden normals
SoftPolyEdgeElements 0;
polyCrease -value 10
//Turn off crease for selected edges
SoftPolyEdgeElements 1;
polyCrease -value 0;
Message 6 of 11
cmoady
Increase the preview divisions
Message 7 of 11
gaboherrera3d
@malcolm_341   Thank you very much, these scripts are very usefull
Message 8 of 11
malcolm_341
Sweet glad you found these useful.
Message 9 of 11
valeriolucentini98
Hey, i am a noob, can someone quickly explain to me how to use these scripts? Thanks!
Message 10 of 11
malcolm_341
@valeriolucentini98 Create three new empty Mel buttons on your custom shelf. If you're not sure how to do that just google it. From there copy the text I posted from each section, the "//" denotes where each script starts and there are three total. Paste each script into one of the Mel buttons you created by right clicking the button choosing edit and then pasting the text into the command section. Close the window and when you click the shelf button it will run that command/script. Select the your mesh and click one of the three buttons to toggle the different modes described above.
Message 11 of 11
valeriolucentini98
Hey thanks for the reply! It worked perfectly 😄
