Announcements
Rendering and UV mapping issues
I am posting a couple screen shots to illustrate what my problem is.  The objects are Ploygon Cubes with a UV map attached.  Can anyone tell me why it is doing this?  I watched several tutorials on UV maps and believe I did it correctly.
It seems like here is some kind of transparency going on but I can't find it.
Thanks.
sean.heasley
Hi @Anonymous and welcome to the community!
It's possible you have Backface Culling on which can be disable by going to Display->Polygons->Backface Culling.
If that doesn't work, you might have accidentally enabled transparency for your material. To fix this, right click the model and select Material Attributes then look for the Transparency slider and make sure there's no texture assigned to it.
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
