Maya LT Forum
Welcome to Autodesk’s Maya LT Forums. Share your knowledge, ask questions, and explore popular Maya LT topics.
Multi-cut not working properly
3 REPLIES 3
randalgitautis
836 Views, 3 Replies
I am not sure if i hit a button to switch something.  When i now hover over an edge or vert with the multi-cut tool. it seems like its ignoring the faces im hovering over and im not able to cut edgeloops.  I can't even click a vert and start from there.  i can still click off the model and drag to "slash" an edgeloop into the model I have opened the tool box and reset tool and close Maya and re-opened.
3 REPLIES 3
Hi @randalgitautis
Thanks for posting! I have not heard of this being an issue before, would you be able to take a screencast of the issue so I can try to replicate the problem on my end?
Also, can you tell me a bit more about your setup?
  1. Have you tried Reseting your Maya Preferences?
  2. What is your GPU? Is it on our list of Certified Hardware?
    1. If on Windows, can you please provide a DxDiag report?
    2. If on a Mac, what OS are you running?
  3. Are you using a Wacom Tablet, Cintiq 3D or Magic Mouse?
  4. Is your Maya software up to date? We have Update 2018.6 for Maya 2018, as well 2019.1 for our most current version, Maya 2019. You can download these updates by signing in to your Autodesk Account
Thanks again for being a part of our community! I look forward to your reply!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Hi @randalgitautis
I hope  you are doing well! I just wanted to check in and see how things were going. Did you have a chance to try my suggestions? Any new developments with this tool?
Jordan Giboney
Im having the same problem in Maya 2022, when i try to use multicut on my mesh it creates a cut somewhere else in space, it does not matter what view i got. i tried to duplicate my mesh, reset my preferences, reset my toolsettings, deleted history, both regular and nondeformative. ive freezed my object i centered the pivot. Seems like multicut thinks my meshe is somewhere else. If i delete some faces and press delete history multicut still tries to put an edge where the now gone faces are. hoorrraayyyy
