License and Maya-to-MayaLT
rcludorc
Observer Observer
rcludorc
Observer
Observer
I wanted to email Autodesk for this issue since there are severals.
https://knowledge.autodesk.com/fr/contact-support/websupport/product-troubleshooting-0
The link does not work and always bounce me back to the previous tab.
As for the actual problem and not the one encountered while attempting to fix the first one:
Can I give you a file that I worked on using a student version and change the metadata to continue the project on a commercial license? Some company do it, if it's possible thanks. Would mostly like not to redo what I've spent 100hs in school.
I use Maya for Modeling, Rigging and Animating, and I'm thinking about shifting to Houdini all but Rigging. Can Maya LT provide me as much power to do those things as the regular Maya does? Could check it on the web I know.
Can I export the Rig from Maya as FBX and load it in LT?
I want to use Maya to Unreal, also.
no this would be against the license agreement you agreed to when you signed up for the student license
