Multiple floating outliner windows
Please make it possible to have multiple separate floating outliners open. This will make it possible to have different objects displayed in each outliner making it much easier to for instance do constraints between multiple objects. Check how that works in Softimage XSI.
The top/down split outliner mode is useless.
7 Comments
userX4542
allow for multiple outliners
peerke88
theres already 2 in the single outliner window if you drag the dotted line up
userX4542
thanks, I know, but multiple outliners would be nice.
userX4542
Posted about this here: https://forums.autodesk.com/t5/maya-ideas/multiple-outliners/idi-p/7977301
There is a script available that allows you to do this. But you're right, it should be an built in feature.
jwlove
I think Maya currently has the ability to essentially have 4 outliners open right now...  You can have the floating window which has a split window capability at the bottom of the window (you just drag it up a little to reveal it).  And you can also open the docked one on the left side of the main interface - the button for it is underneath the panel layout options.  This one also has the split window capability.
trevor.adams
tj.galda
Status changed to: Archived
