Cached playback has no mel output
Hey,
the new cached placback toggle button, two right from the fps setting in the lower right corner does not give a mel output in the script editor.
Even if you you check 'Echo all comands'.
For people who script to spped up their workflow that would be very helpful!
Thanks 🙂
3 Comments
kevin.picott
The reason for that is that the code in the cached playback toggle button is entirely in Python so there is no Mel to output. It's a larger question for us to consider as to why that is and whether it is the right thing to do or not.
For this particular feature though there is a Mel equivalent. These are the two commands to toggle caching off and on (the UI will update automatically to match the new state):
evaluator -n cache -en off;
evaluator -n cache -en on;
tj.galda
zapan669
I believe making pure Python things is not the logic of Maya.
Or you decide to go 100% Python and print each commands in the Script Editor.
But I would fear some **** mix between MEL and Python.
When I think about it, 10 years ago MEL was way Faster than CMDS,  is it still the case ?
If so, then everything in MEL is still a good logic,  I think
