XGen openCL bug
XGen openCL bug
Message 1 of 21
XGen openCL bug
Hi all,
trying to use new interactive splines in 2017 but Maya says that openCL is not enabled. Output window doesn't seem to be much help.
I tried changing different display options for viewport 2.0 in preferences, but no luck.
Does this have something to do with video card options or Maya? I run Nvidia 980 Ti.
Thanks in advance for help!
Replies (20)
Message 2 of 21
pshwayka
Add the following line to your maya.env file:
MAYA_OPENCL_IGNORE_DRIVER_VERSION=1
(See attached for note from hardware compatibility list)
Message 3 of 21
Thanks for a quick reply!
I added the line but still get the same openCL error in Maya.
Looks like my only option is to roll back my GPU driver, but I'll have to wait until Maya supports current Nvidia drivers. I use other applications that require latest GPU drivers.
Thanks for your help anyway!
Message 4 of 21
BTW, is there a timeline on when Maya is planning to support latest GPU drivers for XGen features? It is a bit counter to logic when new features are added but not supported by the software itself.
Thanks.
Message 5 of 21
Michael_Todd
Its not that Maya does not support it, it's an issue with the latest drivers implementation of openCL.
Michael Todd
XGen Product Owner and Designer
Message 6 of 21
Michael_Todd
double post
Michael Todd
Message 7 of 21
Thanks Michael, that explains it. I misunderstood the correlation between GPU-specific implementation and Maya native features.
I do enjoy robustness and control of Xgen features by the way, it's a great solution given the complex nature of CG hair Smiley Happy
Message 8 of 21
Michael_Todd
Just a quick note to mention that the latest drivers from nVidia should fix this issue for you, without any need for envars..
Cheers
Michael Todd
Message 9 of 21
Which driver is that on Linux?
Message 10 of 21
Michael_Todd
Whatever the latest drivers are available. The problem has been fixed in windows drivers for a couple of iterations now, so I would hope the linux versions have the fix too.
You could still use the envar to force Maya to ignore the openCL version
MAYA_IGNORE_OPENCL_VERSION=1
Cheers
Michael Todd
Message 11 of 21
@Michael_Todd
Apologies if this is a bit of a thread hijack, but I was wondering if there's a way to choose an OpenCL device for Maya to use through environment variables. My issue is outlined in a bit more detail here:
https://forums.autodesk.com/t5/maya-forum/select-opencl-device-variable/m-p/6879691
Message 12 of 21
i have that issue too can't open XGen grooming tool in Maya 2017, my GPU Radeon HD 6670 😞 can't openCL
@Anonymous wrote:
Hi all,
Message 13 of 21
Michael_Todd
I'd suggest getting the latest drivers and if that still doesn't work, try the environment variable posted above. OpenCL is a cross platform standard so if it's not working on a particular card, it's probably a driver issue and we don't have control over how the card manufacturers implement it for their cards.
Cheers
Michael Todd
Message 14 of 21
i tried the 2 methods but still have that issue maybe that tool use another generation of openCL and my card didn't support it , but the must thing make me crazy how i can use the grooming tool in the old Xgen without any problem and can't use that new method and they are too similar :|, maybe i will change my card soon 😞  thanks so much for u help 🙂 i will change to nvidia hope it haven't the same issue too 😄
Message 15 of 21
Michael_Todd
You don't happen to have an integrated graphics card as well as the nvidia card do you?
Michael Todd
Message 16 of 21
I can't get this to work so I gave up on this card. I'm going to have to get a different card. This is impossible I can't get it to work, updated the driver 3 times, checked cuda, and opencl works on other apps as well, but heck this is just a waste of time. If you find a solution let me know and post it.
Message 17 of 21
Michael_Todd
Does the environment variable posted above not work?
cheers
Michael Todd
Message 18 of 21
lightSicle
Upgraded my graphics card driver to its latest solved the problem for me!
I am running both Maya 2017sp4 and 2018 on my Windows10 with a NVidia GTX680 graphics card.
I downloaded the latest driver(v388.13) from NVidia's website and it worked, although my previous driver was fairly recent(v358 I think) but it seems that only this latest driver version solves the problem!
I should add that editing the .env file didn't solve the problem for me before upgrading the driver though.
Message 19 of 21
Hey,
I've seen a lot of people posting about how their xgen gives them this error but none of the answers so far have helped....
I'm borrowing a friends PC for a project and it has a nvidia gtx 580 and is running driver 388.13.
I tried to rollback the driver but it is greyed out. I have reset prefs, reinstalled maya and tried the maya.env thing and nothing seems to have worked.
Any suggestions other than buying a new graphics card? 😞
Message 20 of 21
Hi! I have a Nvidia Quadro 3000 and Ive tried everything, still getting the OpenCl note and I cant use interactive grooming 😞
