Xgen lighting problem
Hi all, I am new to Maya Xgen function, I learnt from online tutorial, but still couldn't fix my problem.
I created a rigged model and apply xgen on it, then I reference the rigged xgen model to the animation scene. However when I apply the lighting to the animation scene and render with mental ray, the xgen model becomes totally different. All I want should be similar as the preview in workspace. I use maya 2016 sp6, i applied xgen_hair_physical as geoshader, and i used same map in Primitive Color, tip color and root color since I want to draw the pattern on model. Could you please help me to light it correctly?
Moreover, I have seen in the tutorial about groom bake, should I apply it before rendering the whole animation scene?
Thanks a lot!
Michael_Todd
Can you post a screenshot of the shading network for the hair shader? Also, have you set up custom color expressions for root_color and tip_color?
Michael Todd
XGen Product Owner and Designer
Hi Michael, I do apply expression for root_color and tip_color. btw, i changed from xgen_hair_physical to xgen_hair_phen, please find my shading network, thanks!
Michael_Todd
Take a look at this tutorial:
Mental Ray and Custom Color Expressions
and the documentation:
Shading and Rendering XGen
Cheers
Michael Todd
I followed the tutorial, but i change a bit on tip color since I want the tip and root color are same. However, there are still some problem when i render it with lighting:
1. it doesn't show the white color as the ptex map, i tried to adjust the light setup and the shader setup, but it doen't help;
2. it is too secular , but seems no effect when i adjust the shader setup.
Michael_Todd
I'd try different shaders. mib_illum_hair is not as good as some other shaders available. As for the specular, that's just the shader settings, you have to make adjustments to primary weight and roughness.
Michael Todd
