I really hope someone can help me out here.
Every time I do a change with the groom tools my primitives are updated automatically. That means every time I do a change I have to wait 3 secs for XGen to update my primitives but I don't want XGen to do so. I cleared the XGen preview but XGen still updates after every change I do. Have I ticked some auto update checkbox somewhere? It makes working nearly impossible.
Cheers,
Myoungjun
Hi @Anonymous
So you have the eye icon(preview) disabled but its still forcing updates?
A quick test you could try is unloading and reloading the Xgen plugins and then open your scene and see if this still occurs.
If it is still happening, can you possibly post a video of this issue?
If you need a video capturing program, Screencast is a great option that we use here at Autodesk
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Ok solved it. For some reason I didn't see the check box under the XGen Preview "Update Preview Automatically".
Can be closed.
Hi @Anonymous
Ah there ya go! Thanks for explaining what you did and marking it as the solution!
All the best,
Sean Heasley
